  • Guests: 59
RoV IW3IPD (63)
01/13 si2030 (62)
homemade hv transformer
teslacoolguy
Wed Mar 26 2008, 03:32AM Print
tonight i wound 150 turns or 30g wire around a ferrite core very similar to Link2 5kv psu supply. i wound it in 4 layers, 1st 60 turns 2nd 40 turns 3rd 30 turns and 4th 20 turns with each layer covered with electrical tape. with a 10 turn primary and 6v in i got around 2kv out. I am a little concerned about pushing the input to 12v because of internal arcing and i was wondering if this would be a problem and if i should dip it in varnish or something or if i insulated it inough that it would not be a problem.
Avi
Wed Mar 26 2008, 02:16PM
I once made a flyback using electrical tape as a layer separator, the corona eventually burned a hole through it.
coldcity
Wed Mar 26 2008, 02:25PM
coldcity Registered Member #1406 Joined: Thu Mar 20 2008, 12:12PM
teslacoolguy, are you running this with your 555 driver? I have a similar transformer I'd like to rewind and try with my similar ig coil driver.
Wed Mar 26 2008, 02:44PM
Dipping it in varnish won't hurt and may prolong the lifetime, so do it.
Kizmo
Wed Mar 26 2008, 02:59PM
I have done few experiments with homemade smps HV transformers and i think it is almost impossible to make decent insulation between winding layers. I have tried various plastics, epoxies, cast resins etc and they all fail sooner or later. Single layer coil is way to go.
Like steves CCPS Link2
teslacoolguy
Wed Mar 26 2008, 04:12PM
ok i will dip it all in varnish before i push any more voltage
