  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
ferrite core ?
teslacoolguy
Wed Mar 26 2008, 12:51AM Print
i was wondering if i can glue a E or U ferrite core back together after accidentally breaking and if it will still work.
Bjørn
Wed Mar 26 2008, 01:16AM
The short answer is yes. If you can put it together almost perfectly with no gap then you should not notice any difference for most uses.
teslacoolguy
Wed Mar 26 2008, 01:24AM
im using it to wind a small hv transformer and yes the seam is very small so i think i should be ok
Wed Mar 26 2008, 07:54AM
teslacoolguy wrote ...
If you are using a topology that needs no airgap (SLR, bridge [but that's not so critical]), the performance may be decreased. If you are using a flyback converter or parallel resonant ("zvs flyback driver") then you should be absolutely fine, since you will need additional gap anyway.
