  • Guests: 30
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
diode cap protection
rp181
Mon Mar 24 2008, 02:39PM Print
would theese: Link2
be suitable to protect a 450v, 5500uf capacitor in a coilgun? I was thinking of getting several and putting in parrallel to increase max curent, would that work?
Mon Mar 24 2008, 03:00PM
With only 30A peak current each you might need quite a few in parallel, look for something bigger. Really it depends on how damped your circuit is, if designed for it you can get away without any diodes at all! Put the values of your coil gun into Barry's RLC simulator, the negative current will give you an idea of how much reverse current the diodes will need to handle.
Oops, forgot the link. Link2
rp181
Mon Mar 24 2008, 05:01PM
How can i figure out a approximate peak current? i know it depends on resistance, and inductance, but say the coil was 1ohm, what would be a safe assumption.
Bjørn
Mon Mar 24 2008, 05:34PM
A very safe assumption would be 450 / 1 = 450 A
But with a huge resistance like one ohm you may find that it is so well damped that there will be no significant back EMF at all. You got the link to the simulator, play with it and see what it says.
rp181
Mon Mar 24 2008, 09:26PM
hmmm, didnt think 1 ohm was alot. I think 50 of those diodes in parrallel will work =p. Not taking any risks here.
Electroholic
Tue Mar 25 2008, 04:31AM
rp181
Tue Mar 25 2008, 03:23PM
sweet, so if i understand correctly, those can stand 200 A reverse each, and 3 amp forward constant. Whats the forward peak current?
Bjørn
Tue Mar 25 2008, 03:42PM
It all depends, you have not given any details about your design. Your pulse is likely to be long and if your target speed is 50 m/s you might need a coil that is 50 cm long to avoid the projectile being sucked back and exit the coil in the wrong direction.
rp181
Tue Mar 25 2008, 06:27PM
i have no specific goals =) Just expierementing.
If there is suckback, then ile put 2 of those caps in series for 900v.
Bjørn
Tue Mar 25 2008, 07:19PM
If it conducted both ways it would be a wire and not a diode.
The 200A is forward peak current for one "cycle" worth of time, there is a nice table in the datasheet that shows current vs cycles. If you assume that one cycle is 16.7 ms then you should normally be fine.
