  • Guests: 41
01/13 si2030 (62)
Help with singing arc project?
lpfthings
Mon Mar 24 2008, 04:09AM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I saw a video on youtube using this driver, and would like to give it a try myself. The problem is with finding the IC. Theres only a few sites that have them. Is there a substitue that will work also? It would be good to get one locally, but that doesnt seem to be the case. Id there a circui tht works just as well, not as complicated and uses readily avaliable parts?
Thanks
[Edit: Fixed link]
Mon Mar 24 2008, 07:59AM
Hi, if you don't need hi-fi sound then you can use a 555 +MOSFET driver, and you input your audio to pin 5 of the 555 via a 0.1uF cap.
As to the IC, KA3525 is the same as SG3525. The singing arc would work also with TL494 but it's not pin-compatible with SG3525 and it would need a bit different circuit.
Mathias
Mon Mar 24 2008, 09:45PM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
the TL494 needs even less components to work
link
lpfthings
Tue Mar 25 2008, 05:18AM
Yes, but there is more to that circuit, there are 2 IC's in that one. Thanks for the help. Do you have a circuit for the 555 timer one? i have searched google and found a few, i want to be sure that i make the right one.
Tue Mar 25 2008, 09:02AM
Mathias wrote ...
link
The SG3525 can be made to work with minimal components too but I've added decoupling caps everywhere as it decreases the picked-up mains hum that may occur or interference from HV output.
"Do you have a circuit for the 555 timer one?"
Just use the classic schematic with 2 resistors and one cap, and connect your audio to pin 5 through a 100n cap. The output of the 555 goes to the gate of a power MOSFET which drives your HV transformer.
lpfthings
Tue Mar 25 2008, 10:27AM
Sorry for all the questions. Is this the one to use? Link2
