  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
400kHz 50%duty cycle oscillator
Marko
Sun Mar 23 2008, 03:38PM Print
I want to do it with least number of easily available components. I'd also like to vary the frequency for at least some +-100..200kHz while maintaining exact duty cycle.
common NE555 has upper limit of 500kHz and it seems impossible to achieve stable duty cycle there. I tried several NE555 circuits, also one with external transistor which is supposed to keep 50% duty cycle, which worked to a point but loses as frequency approaches maximum.
CMOS 555 works for higher frequencies but I don't have it here and I don't think it would have stable duty cycle either.
Only verified solution I know would be 74HC14 + 74HC74 flip-flop multivibrator, which would divide the oscillator output by 2 and always keep 50% duty cycle.
But this would take me 2 additional big IC's so I'm just wondering if I could do it simpler way.
Wouldn't like to have to use 4046 either, as this is a SSTC driver circuit I'm actually trying to get rid of it angry
I have lots of opamps, comparators and various common logic IC's around here, I'd love to see some ideas.
Marko
Sun Mar 23 2008, 03:51PM
CD4047? I don't know the max. frequency but I think its over a MHz
ShawnLG
Sun Mar 23 2008, 04:03PM
Have a look at this.
Zum Beispiel
Sun Mar 23 2008, 04:16PM
Yes, the 4047 is a wonderful little IC. Highly recommend it.
Marko
Mon Mar 24 2008, 12:21AM
After some research, it looks like I'm condemned to use a bistable and some simple non-50% duty cycle oscillator, or an IC containing all that (I don't have 4047 in my stash, though).
Shawn, I don't have a negative supply in my circuit and circuit expectedly doesn't work without it with LM393, since positive input can never get lower than negative.
Also, duty cycle turns pretty uneven even at about 100kHz. LM311 is faster, but I'm not sure if it would work well enough at 500kHz.
I have one faster comparator but it's quite expensive and I wouldn't like to use it for that.
It just looks like analog approach for 50% d.c. is not a way to go.
I'm going to try some more complex comparator circuits but I'm not sure if they are worth.
Can anyone by the way tell, how does the high-frequency VCO (first circuit on page 6) create linear sawtooth only with comparators and passive components, without any current sources in sight? Or is it just approximate?
Carbon_Rod
Mon Mar 24 2008, 08:42AM
PIC12C508 with internal 4MHz RC oscillator calibration factory set.
IIRC something like this needs no recalibration for many units...
INCLUDE <P12C508.inc>
org 0
goto start
org 4
start:
movlw 0x00
movwf GPIO
TRIS GPIO
loop:
bcf GPIO,5
nop
nop
nop
goto next
next:
bsf GPIO,5
nop
nop
nop
goto loop
edit:
for adjustable frequency just change to an external RC oscillator.
