  • Guests: 70
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
Nd:Yag ssy1 laser
EEYORE
Sat Feb 11 2006, 06:36AM Print
Ive got laser fever again ,and bought another ssy1 head on ebay for an unbelievable price of 77$!!!Last one i bought was 125$....
So far its all mounted nicely on perf board with a small inverter to charge the capacitors. With just plain electrolytics, ive manged to put holes on Al foil(Yeehaw!)
Im currently looking for some photo flash caps, as they have lower ESR and all, which means faster pulse(good for Nd:Yag)
Id much rather find a large film capacitor, for better operation.Ive pushed it up to 40J in to the flashlamp(almost 3times the rated max)Q-switch still inside...
Pics to come soon(i need a new memory card for my digicam...says card uninitialized?)
stay tuned...
Matt
Eric
Sat Feb 11 2006, 06:58AM
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
You might look for high voltage oil caps as well as photoflash electrolytics. I've got some 40uF/2500V oil capacitors I figure would be perfect. A little overkill in the voltage department but extremely low esr compared to electrolytics.
I bought one of those ssy1 also, haven't hooked it up yet. Would be interested to see pics...
Sat Feb 11 2006, 07:37AM
I would just get one of the auctions for 4 original pfn's off ebay. There are none right now, but they turn up quite often smile
Parallel a few for bigger pulses shades
With your digicam, you need to format the card. It is uaually in the menu somewhere.
Michael W.
Sat Feb 11 2006, 03:50PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
So what is needed for a Nd:Yag laser, A flash Lamp, A laser head, a driver? What else?
EEYORE
Sat Feb 11 2006, 07:02PM
ForceLabs wrote ...
A laser head contains everything needed but the PSU/PFN....
I tried to format the card, still says uninitialized...
Matt
Marko
Sat Feb 11 2006, 07:28PM
I was wondering why only xenon flashers and leds (for CW) could be used as pump sources...
There are lots of much easier IR sources dead
As I figured out ndyag resonator usually divides wavelenght, so it only needs to be in focus of some source of IR, why couldnt a some powerful halogen lamp with IR filter be used confused
As i never saw anything more powerful than 5mw diode I have to ask such noob questions... cheesey
Eric
Sat Feb 11 2006, 08:36PM
Hey guys, we should probably take general discussion of ndyag lasers to the thread already setup for that and leave this one just for stuff directly relevant to mattrg2's project....tis the rules. Link2
