  • Guests: 51
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Can a flash tube light continuously?
Plasmaarc452
Sat Mar 22 2008, 04:23AM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
I have wanted to know this for some time, i mean they are REALLY bright when they are flashed but if they were on all the time it would be like a flashlight from hell.
I know that it takes a lot of power to light it for a millisecond but suppose i had an unlimited power source capable of providing that amount of power continuously.
It might sound like a dumb question but this it would be really cool if it is possible for projects ect...
ShawnLG
Sat Mar 22 2008, 05:44AM
They would explode when run continuously like that.
"I know that it takes a lot of power to light it for a millisecond"
Some of that power is dissapated as heat in the tube. Integrate that power for a longer period of time than a millisecond and you will see why it is not possible.
Sat Mar 22 2008, 05:49AM
I wonder if it would be possible to water cool the tube for continious use. It would make focusing the light a lot harder but just for the take of trying it would be interesting.
flannelhead
Sat Mar 22 2008, 06:27AM
Heh...
I put a small disposable camera flash tube on my small TC. Very nice effects, but it got too hot to touch in 15 seconds. So the heating will be a big problem!
In the other hand, I managed to light one continuously with my small CW, but I used a 10M limiting resistor...
Sat Mar 22 2008, 09:26AM
Unlike conduction is metals, where resistance rises as temperature increases, resistance actually falls once an ionized gas has started to conduct, so that more current flows, heating the gas still further. Thus the ionized gas behaves as a negative resistance.
This is why ordinary mercury vapour fluorescent lights need ballast - a resistor in its simplest form, or an inductor - to keep them within their safe operating area - to prevent thermal runaway that would very quickly destroy the tube.
The camera flash tube is best considered as a switch or gas relay. When it is OFF, its resistance is very high in the gigohm range. Once the tube has been triggered ON, the gas starts conducting and heats up so its resistance falls very rapidly to a low value, perhaps 100 milliohm. A very large current is able to flow from the capacitor very quickly in a short pulse.
Bored Chemist
Sat Mar 22 2008, 09:54AM
You can run these tubes continuously. I've done it, but you need a balast resistor ( as Harry said) I think there's someone on this site who uses such a tube as an avatar.
Tesladownunder
Sat Mar 22 2008, 12:43PM
I've done some pictures just for you.
Here is a strobe light tube running on DC through a 100k resistor. Self triggered at 5kV then dropped to about 240 V across it at 9 mA.
Second photo is with the camera moving to show the near constant output with only a little ripple. Third photo shows the effect of a NIB magnet like in the avatar mentioned before.
Helium Neon lasers are a bit similar with a negative resistance region. They use a 70K resistor in series to keep it in the positive range otherwise it will turn on and off like a relaxation oscillator.
TDU
1206189244 10 FT41613 Flashtubestrobedc
1206189244 10 FT41613 Flashtubestrobedcblur
1206189244 10 FT41613 Flashtubestrobedcmagnet
lpfthings
Sat Mar 22 2008, 02:17PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I know you can send HV through them continously, like TDU has done above, but having it continously "flashing" isnt really possible without some major cooling issues.
Sat Mar 22 2008, 02:22PM
Those 10w horseshoe tubes can be submerged under water (as long as you leave the electrodes exposed you do not need to worry about the normal problems associated with hv and water cooling) and be run with about 100w average power. Unfortunately at this region the efficiency of the tube is quite poor and I would estimate <10w optical power out.
Ken M.
If cooling is an issue with continuos operation, and since water conducts, perhaps use a container of clear oil and maybe place some AL foil on 1/2 the oil filled container.
