  • Guests: 39
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Scope timebase query - HP1725A
coldcity
Thu Mar 20 2008, 12:15PM Print
coldcity Registered Member #1406 Joined: Thu Mar 20 2008, 12:12PM
Hi all, I have a lovely (cheap from the 'bay) HP 1725A 275Mhz scope.
The only flaw is it's missing it's timebase knob. I've attached a substitute, but the timebase scales were on the knob itself. I'm just trying to work out the range of steps.
From Googled spec: "Sweep ranges from 10 ns/div to 0.5 Sec/div (24 ranges), 1-2-5 sequence."
I think that means I have the following ranges:
10ns
20ns
50ns
100ns
200ns
500ns
1000ns
2000ns
5000ns
0.01ms
0.02ms
0.05ms
0.1ms
0.2ms
0.5ms
1ms
2ms
5ms
10ms
20ms
50ms
0.1s
0.2s
0.5s
Can anyone confirm that? Ideally by glancing at their HP1725A? :D
Many thanks for any help you can offer.
GeordieBoy
Thu Mar 20 2008, 12:43PM
Sounds right.
...and you should be able to check out most of those settings with various sources...
2ms/div to 50ms/div with local mains line frequency,
100us/div to 2ms/div with 1kHz probe test signal,
faster timebase settings will need some known high frequency oscillator
coldcity
Thu Mar 20 2008, 01:04PM
Indeed - from my testing the longer ranges do look right :)
