  • Guests: 51
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
I need help identifying scooter part.
Tue Mar 18 2008, 10:00PM Print
The part came from the electronics(obviously)part of a gas powered scooter. I have seen these in purely electric scooters too. It is in a metal case and the bottom looks like some sort of stuff like they fill flyback transformers with except black.
The scooter has a horn blinkers and when you hit the brake it lights up two brake lights,and has electric start. Anyone have a clue as to what it may be?
1205877614 1225 FT0 Unknown Scooter Part1
Wed Mar 19 2008, 12:24AM
Knowing what it connects to would make it a lot easier to figure out what it does... The first thing that comes to mind would be the module for a pointless ignition system, but that woulnd't fit well with electric scooters...
Judging by the fact that it was designed to be able to dissapate a bit of power I would assume it has something to do with the battery, either some type of charger or protection circuit.
Wed Mar 19 2008, 12:52AM
Well it is not electric. If anyone can figure out what it is i would appreciate it if they could show me a pin out.
Myke
Wed Mar 19 2008, 04:44AM
Arcstarter wrote ...
Well it is not electric...
It's not? Then no idea because those colored things in the pic sure look like wires to me.
I think it might be a motor controller? Are there wires (if they are wires) that we can't see in the pic?
EDY19
Wed Mar 19 2008, 05:44AM
I think that he means that the scooter that this part was taken from is not electric, not the module itself- I had to read that a couple times, too smile
Bjørn
Wed Mar 19 2008, 07:47AM
On the picture there are no high voltage connections visible so it looks a bit like a voltage regulator.
Wed Mar 19 2008, 05:39PM
Myke wrote ...
there are four wires. Two green,one red,and one is yellow.
Electroholic
Wed Mar 19 2008, 06:00PM
could be the bridge rectifier then.
Test it with a multi meter, I think the green ones would be the AC side.
Experimentonomen
Wed Mar 19 2008, 07:25PM
Looks like a electronic ignition and such stuff module (cde or whatever its called)
Wed Mar 19 2008, 09:42PM
Electroholic wrote ...
I dont think it would be a rectifier. The battery is already dc and the charger outputs dc and even if it didn't it would not need such a big rectifier
