  • Guests: 41
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Centrifuge for getting Deuterium?
Backyard Skunkworks
Sun Mar 16 2008, 07:21PM Print
If you had a centrifuge containing hydrogen gas, wouldn’t the heavier deuterium begin to concentrate on the walls? If you had like a thousand liters of hydrogen, wouldn’t this begin to produce a noticeable/usable amount of deuterium?
DrZoidberg
Mon Mar 17 2008, 06:33PM
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
If the centrifuge is spinning fast enough. Centrifuges are used to enrich uranium so they would probably also work for deuterium. But there are more efficient ways.
Here is a description of how deuterium is enriched.
But I don't think you'll be able to do that at home.
