  • Guests: 103
26 inch Jacobs ladder arc from domestic service
Tesladownunder
Sun Mar 16 2008, 11:19AM Print
Ran my 60kV x-ray transformer (at 2/3 power). A nice series of pics.
TDU
1205666315 10 FT0 Hvxray60whole
1205666315 10 FT0 Hvxray60specsplate
1205666315 10 FT0 Hvxray60start
1205666315 10 FT0 Hvxray60escaping
1205666315 10 FT0 Hvxray6026inch
Sun Mar 16 2008, 11:27AM
TDU, I see your getting back to the arc business, nice! cheesey
The 60KV 300mA rating is continuous? amazed That is 18KVA of power!
Tesladownunder
Sun Mar 16 2008, 12:19PM
I guess those are continuous ratings. Note that I am driving only one phase (I think). Assuming there are 3 phases at 242V 45A, what is the total power? 11kW x 3 seems the wrong figure for 18kW out. It is a very heavy unit at about 300kg.
Running into a 200k load it draws 25A at perhaps 100v. The arc "escaped" the load and jumped onto the back sheet metal and rose at full power. Once it tripped a 40A breaker plus RCD but there was also a 20A in series which didn't blow. I wasn't using my 32A outlet so the tiny mains leads got quite warm.
It really surprised me how high it went.
My wife came out to complain about the brownout suprised (things are serious when it interferes with TV). Once a couple of kW of stuff was turned off elsewhere, things were OK for multiple shots.
Here is my HV resistor made from 5 feet of 1/2 in tubing. Copper attachments and a valve for replacing/filling/adjusting. Works great and got so hot that it cavitated with boiling or electrolysis. Survived nicely. Currently set for 200k with a combination of tap water and copper sulphate. A tip: don't try to measure it with a meter. The metals seem to generate 350mV and mess up an ohmmeter. Use 10V and a current meter (50uA).
TDU
1205669902 10 FT41222 Hvresistor10mm200k
Fri Mar 21 2008, 02:53PM
TDU - I dare you to beat this: Link2
o_O
Tesladownunder
Fri Mar 21 2008, 03:36PM
I am no competition for Matthias. He winds his own transformers up to an amazing 400kV and has done professional plastics welding for his containers. Superb construction and the Germans also seem to have a huge amount of 3 phase power available to the home.
I have had many email contacts with Matthias and have invited him here.
TDU
