  • Guests: 23
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
camera flash transistor keeps blowing
teslacoolguy
Fri Mar 14 2008, 03:06AM Print
i am trying to make a multi camera flash device that puts out a enormus amount of light for a split second so i banked up 4 xenon tubes from disposable cameras along with a 200uf flash cap instead of 120uf and after playing with it for a while i got it to work well but it would keep blowing the transistor tht is used to oscillate the inverter transformer. Why is it doing this and how do you think i can fix this problem?
Fri Mar 14 2008, 03:31PM
Try disconnecting the charger before firing, it's is good practice anyway. I'm not too familiar with camera-chargers, but since they don't seem to use mechanical switching there must be some silicon somewhere which controls the switching process. 4 xenon tubes VS 1 should have ~1/4 of the resistance, so the increased peak current might be the problem.
teslacoolguy
Fri Mar 14 2008, 05:49PM
disconnecting the power from the charger before i triggered it worked. Now i have to design a circut that cuts the power to the flash unit a couple ms before the flash triggers via a scr then returns power to the flash unit and then triggers the scr again to start the recharge so any suggestions on how to do that will be appereciated.
this is the sequence that i need. power off then around 1ms later scr on for 1ms and power stays off through the entire time the scr is on so 4ms then power turns back on and 1ms later the scr turns on for 1ms to start the recharge and the power stays on to recharge the unit and then when i push the button not holding it down the process starts all over. i was thinking of using a small pic connected to a 4017 chip but i think there are better ways.
flannelhead
Fri Mar 14 2008, 06:32PM
teslacoolguy wrote ...
Strange problem...
Uzzors wrote ...
The triggering done with a trigger transformer. The trigger transformer generates a pulse of some kV which ionizes the gas in the tube. Then the 200V in the caps have free way to go. So there should be no silicon in the trigger circuitry.
As Uzzors said, it could be the 1/4 of the normal resistance which caused the transistor death. I've never had a problem with a single flash tube and 480uF@330V. You should also try paralleling the caps, it should increase the brightness.
Backyard Skunkworks
Fri Mar 14 2008, 08:29PM
Maybe your best bet is finding some other way of ionizing the Xenon tube, after all these cameras are built for taking 27 pictures and have the bare minimum of beefy-ness required. I've even had some charging circuits fail during normal use of the camera! amazed
The caps are pretty versitile but the charing circuitry just isnt built for anything more then a few mA at 330 volts and a 10kV pulse.
Speaking of camera inverters I did a little experiment and a few of these things in parallel using NiMH batteries is enough voltage and current to electrolyze tap water, although its pretty slow.
Tesladownunder
Sat Mar 15 2008, 12:28PM
I used a camera circuit in my Candy Box HV.
I had figured the load would be too much for the existing transistor and I substituted it for a BD140. Been reliable for years running 3V of alkaline batteries (instead of the designed 1.5V). I have used a heat sink so I guess the BD140 might have been getting warm.
TDU
Sat Mar 15 2008, 08:54PM
yep, those transistors work just fine when used normally, but it looks like they can't handle anything more than a momentary overload. I learned this the hard way when building a 6 inverter HV generator and blew out 4 pairs (!) the first time I attempted to draw sparks.
For future reference, I had to put resistors in the grounds from each CCFL transformer to get around this.
-A
