  • Guests: 29
Weston (30)
TheMooseGoesMoo (33)
09/24 Rollingblackout (50)
09/24 ScottyNZ (47)
09/25 KresoLiubov (40)
How to rise output voltage of inverter
Paracetamol
Wed Mar 12 2008, 03:22AM Print
Paracetamol Registered Member #1387 Joined: Tue Mar 11 2008, 04:14PM
So, I'm trying to load my caps with 12VDC -> 230VAC inverter and it works fine. It gives about 320V when I rectify the voltage.
But is there any rather easy way to rise the voltage to about 380V or even higher to 750V? I won't be breaking the inverter up, because I need it for other uses as well.
I have tried to build Villard voltage doubler to be used with the inverter, but with no luck. It gave out just 28V. (??)
Any hints would be welcome, as I'm a bit newbie with electronics.
Bjørn
Wed Mar 12 2008, 03:28AM
Have a look at this: Link2
Also here for how to use a transformer: Link2
Paracetamol
Wed Mar 12 2008, 04:13AM
Mmm.. I build Charge-Pump Voltage Doubler as instructed on the wiki. But it is obviously sucking too much juice, because my inverter switch off and blinks "overload" light. Putting a resistor between the inverter and voltage doubler does help, but the output is just a bit over 50V.
Bjørn
Wed Mar 12 2008, 04:41AM
Did you ground one of the outputs from the inverter like the diagram shows? That might be a bad idea depending on where you live.
Paracetamol
Wed Mar 12 2008, 05:19AM
I didn't ground any of the outputs or anything. Why would it be a bad idea?
Bjørn
Wed Mar 12 2008, 06:04AM
In some countries one of the wires is at ground level but in other countries both the wires have a voltage relative ground level. So if you ground one of them you might blow a fuse or something else that is not desirable.
Something strange is going on with your voltage doubler so you need to debug it to find out what.
GeordieBoy
Wed Mar 12 2008, 10:01AM
Most solid-state switching inverters do not like a capacitive load.
Paracetamol
Wed Mar 12 2008, 03:32PM
Thank you all for your help, I got the voltage doubler working. One diode was just burned somehow, stupid me.
Paracetamol
Mon Mar 17 2008, 08:03PM
Heh.. A new problem. The voltage double is working perfectly, it rises the voltage to 600V pretty fast.
So I thought "oh, what the heck, let's get it even higher!", and build a voltage tripler. It works nicely, loads it's own caps to over 900V, but when I'm trying to load my coil guns caps (2x450V 4700uF in series), it just doesn't work. The voltage stays at 4-7V.
I made the tripler several ways and they all "worked" alone, but not with those big caps.
So.. any pretty advices? You have been so helpful for so far.
