  • Guests: 26
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Long exposition picture as a movie?
Mates
Sun Mar 09 2008, 08:23PM Print
High guys, I have one theoretical concept…
I noticed that some of you are playing with the design of digital high speed cameras so I have a question, alternatively a challenge for some of you…
Once working with digital camera for taking pictures of sparks I usually set long exposition time (around 10s) and only play with the ISO and the aperture. My point is whether there is a possibility to make the occurrence of the final 10s exposition image as movie? In other words, there will be only one picture (background) a new signal in the movie will be continuously added into the first picture…
Is it doable?
here is a movie of what I mean, based on software processing (additive slide shhow) Link2
Bjørn
Mon Mar 10 2008, 03:01AM
No, when the sparks are overlapping on the same exposure there is very little that can be done. If you use a rotating mirror to place the sparks side by side it is possible to split up the image into frames and make a movie.
