  • Guests: 31
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
igbt diode question
Sun Mar 09 2008, 07:47PM Print
I'm not sure about the rating of the anti-parallel diode of this igbt: Link2 ,it is not mentioned it in the datasheet.
Am i safe to assume the same rating as the igbt, this means 60A@25°C, 30A@100°C, 200A pulsed?
tesla500
Sun Mar 09 2008, 08:15PM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
Hi Jan,
I don't think that assumption would be safe. I've seen many IGBTs with anti-parallel diodes having a much lower current rating than the IGBT itself. You could ask the manufacturer about the diode's rating.
David
pbfree
Tue Mar 11 2008, 08:31AM
pbfree Registered Member #1386 Joined: Tue Mar 11 2008, 08:16AM
I believe the spec is there just hard to see. Look at Fiqure 16 Emitter-collector diode characteristics. Looks like 20A is max
