  • Guests: 48
Help I.D. odd component..
dan
Mon Mar 13 2006, 06:34AM Print
dan Registered Member #223 Joined: Mon Feb 20 2006, 06:42PM
I found an odd componet in an old monitor. I have seen them before in monitors but never bothered finding out what they were. I tried entering their part numbers into alldatasheet.com but have found nothing. It is basically A small box with three leads. I took one apart and inside were two ceramic like disks; Both disks are of different size and are seperated by a metal plate. This metal plate is conneted to one of the leads of the device. The other two leads connect to spring like contacts that push the disks agianst the metal plate.
I hope I described it clearly enough for someone to be able to identify it.. I have been working with electronics for a long time so it bugs me not knowing what this thing is..
P.S. The disks look like the backs of pizoeletric speakers. Also on the circuit board the device was labled "PTH1'
Desmogod
Mon Mar 13 2006, 07:30AM
Right nest to the power in?
Those will be MOV's
dan
Mon Mar 13 2006, 07:37AM
Yes it is near the power in but Metal oxide varistors look like ceramic disk capacitors with two leads.. but this thing is a small black box with three leads..
here is a diagram: (sorry this is the best I can do with MSpaint..)
Odd Componet
Bennem
Mon Mar 13 2006, 08:44AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi Dan,
This device is a degausing thermistor which supplies the degausing coil, fitted around the CRT, with a desending current when the monitor is first turned on.
Dr. Shark
Mon Mar 13 2006, 08:50AM
I second that, this is also described on SAMs repair FAQ.
dan
Mon Mar 13 2006, 07:42PM
Seems you are right.. Very interesting device.. probably not much use anywhere else but it's nice to know what is it.. Thanks.
