  • Guests: 56
I need some help.. (with voltage multiplier)
Electroholic
Sat Apr 05 2008, 05:40AM
what wattage was your 10k resistor, it will be burning off a few watts if you short the outputs.
chek
Sat Apr 05 2008, 06:05AM
chek Registered Member #1373 Joined: Tue Mar 04 2008, 12:45PM
can u suggest any type of resistor that can be apply to my project...
Myke
Sat Apr 05 2008, 07:58AM
String of smaller valued resistors in series to stand the voltage and also dissipate heat better?
1-2W resistors stringed together? Or should the wattage be higher?
Ultra7
Sat Apr 05 2008, 05:02PM
I don't want to be a bummer here, but the rules of the forum are being seriously bent by this thread.
chek
Sun Apr 06 2008, 06:26AM
Ultra7 wrote ...
i don't understand whats your point...
Andyman
Sun Apr 06 2008, 06:46AM
I think he means about do as much of your own research as you can first. Remember, Google is your best friend.
chek
Sun Apr 06 2008, 07:50AM
Andyman wrote ...
i just trying to ask for opinion, asking i think is a way of doing a research..maybe a beginner should not ask and just reading until he give up??what a waste...
Mates
Sun Apr 06 2008, 10:01AM
I also think you questions are OK. At least I don't mind.
I'm using for my CW Link2 a string of 10pc 2W/100K resistors dipped in oil... Link2 They work pretty well...
Cheers...
BTW:
Ultra7, I do not know how well settled you are here on this forum, but the common practice here is, that in case you do not like something about some particular thread you should contact the Admins and leave all the warning messages on them...
Ultra7
Sun Apr 06 2008, 03:52PM
Hey, I'm cool.
If ya'll are cool, then I'm cool.
I just didn't think we were supposed to be doing someone else's homework for them.
But I'm not trying to start trouble, if thats what ya mean.
chek
Sun Apr 06 2008, 04:16PM
thanks mates...that maybe the problems..i had change the resistor with high voltage resistor...maybe can solve this problem...
