  • Guests: 30
Flash lamp coil gun
Myke
Fri Mar 07 2008, 11:31PM
Depends on the inductance and resistance of the load and that caps and the wires and everything else.
There is this RCL calculator that you can use to find the peak current in your setup but I don't have a link.
Sat Mar 08 2008, 03:40AM
Is it close to 200 amps peak though?
Bjørn
Sat Mar 08 2008, 04:55AM
First of all read this Link2 and this Link2 then go here to the RCL simulator Link2
Everything you have asked and is likely to ask has been asked and answered on the forum before. Search the archives or add site:4hv.org to your google searches.
Tue Mar 11 2008, 03:26AM
I will be testing the flash lamp idea tomorrow with my 1000 uf 400 volt bank. I got a 300 A peak SCR from Frys and made the working coil gun with ok results using 3 flash caps.
Myke
Tue Mar 11 2008, 06:02AM
That's 80J if I did the math right. I would suggest a blast shield to protect yourself from the tube if it decides it can't handle that much energy. Just to be safe.
im_an_alien
Tue Mar 11 2008, 08:43PM
im_an_alien Registered Member #1375 Joined: Tue Mar 04 2008, 09:32PM
How do you calculate the joules?
ramses
Tue Mar 11 2008, 09:04PM
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
I am an alien:
E=CV^2/2
where:
C= Capacitance in farads
V= volts
E= energy in joules.
and i agree completely with Myke about the blast shield. especially considering that you are running it at ~8x rated energy.
i ran a nice one without problems at 4x rated, but that doesn't say much, given that you flash tube is probably a lot younger, and thus less well made, than mine
additionally, SCRs can usually be overdriven a bit (what can't, keeping really tight tolerances is more costly than overshooting the ratings)
"do ya feel lucky, punk?"-some movie that i forget
ramses
