  • Guests: 75
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Transformer question
Mon Mar 03 2008, 03:15PM Print
If I connect a transformer like in the schematic, what will be the maximum current I can draw from the output, 1A or 10A?
1204557270 152 FT0 Transformer
Marko
Mon Mar 03 2008, 04:17PM
That's known as 'boost' transformer configuration - you'll safely be able to draw the transformer's secondary rated current, that is, 10A.
guich
Mon Mar 03 2008, 05:22PM
guich Registered Member #1269 Joined: Sat Jan 26 2008, 06:22PM
no thats wrong i think: The primary has only a current of 1A so you only can draw 1A
Mon Mar 03 2008, 07:07PM
No, you can draw the full rated secondary current (10a).
The output is in parallel with the primary (1a) winding, so its current rating does not apply.
Mon Mar 03 2008, 07:35PM
Thanks
kell
Mon Mar 03 2008, 08:09PM
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
Marko wrote ...
The output is lower than the input, so isn't it buck? Boost would be the other way around.
Mon Mar 03 2008, 08:21PM
I say 11 amps :)
10 amps via the 23V winding and 1A from the 230 V winding.
(Assuming that the phases of the windings are correct)
There are a few ways to look at it but the simplest is conservation of energy
253 V @ 10A in, 230V @ 11A out.
tesla500
Mon Mar 03 2008, 08:22PM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
Actually you can draw more than 10A from the output. You can draw an output current that causes 10A to be drawn from the input, because the input current goes through the 10A rated secondary.
For this configuration, the maximum output current is the sum of the two winding current ratings, so you can safely draw 11A from the output.
David
Mon Mar 03 2008, 08:41PM
Sulaiman wrote ...
I say 11 amps :)
But what assures "sharing" of current between the windings, wire resistance? or am I missing something?
ramses
Mon Mar 03 2008, 09:00PM
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
i would say 1 amp because at 10 a from the 23v winding( the max) it will draw 1a from 230v. but keep in mind that transformers can usually be overdriven by a significant amount...
