  • Guests: 15
rev (49)
Cheech707 (35)
M_Gargantua (35)
nyditch (39)
07/20 rev (49)
07/20 Cheech707 (35)
07/20 M_Gargantua (35)
Laser Easdropping Systems
teslaguy
Sun Mar 02 2008, 06:03AM Print
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
Ive done a bit of research on the systems and I was wondering if anyone knows exactly how to record a reflection and translate it into sounds. I have only played with a simple red laser pointer but there is really a huge deflection and it would be cool if I could learn some more about this and possibly build a laser mic, or it might be one hell of a project for someone with experience with lasers.
lpfthings
Sun Mar 02 2008, 10:27AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
If you could find some sort of mic/amplifier in one circuit, then all youd need would be a audio transformer and laser, and a couple of batts. Search google for "laser transmitter".
Sun Mar 02 2008, 04:02PM
Use GOOGLE. There are plenty of resources out there showing how to do this.
Its actually an easy project as far as the electronics go. Just a simple demodulator circuit is required.
The hard part of course is aligning the laser and receiver which is extremely difficult.
This is definitely not something you just carry around with you and set-up at your convenience. It took me nearly two weeks to work out alignment issues using highly precision lab tripods to listen at a target 50 feet away.
Plus they really don't work that well at all. I was barely able to understand any sounds i was hearing.
You really only see these things in the movies. The various intelligency agencies have experimented with these, but practically speaking, they found much easier ways to do their listening.
Ken M.
Sun Mar 02 2008, 04:23PM
Besides, If your gonna easdrop on someone it might not be too successful if they spot a laser dot, and look your way, sure you could try and bluff out of it but for the most part youd be better of trying to make a small SMD mic transmitter and a wireless reciver disquised as a walkman or something.
teslaguy
Mon Mar 03 2008, 12:21AM
Im not actually going to use it against someone, I would just like to see if I could do it. And i think the laser from a cdrw drive could solve the problem of the red dot.
Ken M.
Mon Mar 03 2008, 01:30AM
I think the CDRW laser would defuse too much, if you tryed to go over say 10ft, but I'm not sure.
Mon Mar 03 2008, 02:15AM
The laser in a cdrw drive is (or at least damn should be) a single mode diode, so as long as you have some decent optics you should not have much trouble getting a nice beam out of it.
Of course getting the alignment corrent is going to be almost impossible...
Mon Mar 03 2008, 02:34AM
Ken M. wrote ...
Thats why you use an infrared laser. Of course that makes alignment that much more difficult.
teslaguy
Mon Mar 03 2008, 03:41AM
I would like to see this working even 3 feet away from a window, just as a proof of concept thing. I found a good demodulator circuit and im going to see if that works next weekend i think. if i combine this: Link2 with possibly this: Link2
or would that do something nasty to the waveform and distort it to much? thanks.
