  • Guests: 35
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Small cap bank quick question
Sat Mar 01 2008, 05:42PM Print
I'm building a cap bank from inverter PSU caps, total 6000uF 200V. I plan shorting it across various types of loads, including inductive.
Would 4x 15A diodes in parallel be enough to catch any inductive ringing that may occur, or do I need stronger diodes?
Thanks
EDY19
Sat Mar 01 2008, 05:59PM
I guess it depends on how inductive the load is, but I have a 11,200uF 400V capacitor bank, and a 2x 40A 600V diodes in parallel with the load and it hasn't given me any problems yet.
pbfree
Tue Mar 11 2008, 08:39AM
pbfree Registered Member #1386 Joined: Tue Mar 11 2008, 08:16AM
Depends on load and surge current of the diodes. Generally diodes have a non repetitive surge current of 10 times the average current. If you have the data sheet of the diode, which you should, find the surge and extrapolate
