  • Guests: 42
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Digital Logic / Counter question
Sat Mar 01 2008, 01:28PM Print
Looking for the help of some digital experts here (as i am not)
I have a photographic application in which an event will trigger a 4-bit digital counter (i.e. 74161)
Is there a simple way to make the count terminate after a single count (0-15)? Sure, i can do it with multiple
gates sampling the output and feeding back through gates to the ENA pin of the counter, but i'm trying to
do this as simple as possible with as small a number of chips as possible. And without going uProc as well. Needs
to be discrete logic.
I guess basically its just a one-shot 4-bit counter i'm looking for.
Thanks
Dan
Ken M.
Sat Mar 01 2008, 03:54PM
Here ever hows this for a 4bit counter? This will count to 15 and immediately reset to 0.
1204386692 618 FT40285 74161 Counter
Bjørn
Sat Mar 01 2008, 04:21PM
Do you want to count 15 or 16 events? If it counts from 0 to 15 then you have only counted 15 events.
If you want to count 16 then you can use the above circuit and feed the carry into the enable instead of reset, then it will stop counting after 16 events.
Ken M.
Sat Mar 01 2008, 05:54PM
Well if he wants it to count from any number otehr then 0 I'd say just load some switches onto a-d and on load, then set it to the desired start # and load the bits, then start teh counter.Aslo I thought about runig it to the enable pin, but then he'd need a lacth with reset, because since its a logic device the CRO pin is always low, untill it counts to 15 then it goes high, so if you fed the CRO pin to enable directly it wouldn't work at all since it has to be held high to run, If you kept the inverter but just sent the output to enable then it would just reset the same as mine does anyways.
Sat Mar 01 2008, 10:22PM
Actually it needs to count to 15, but then stop counting until another enable pulse is received. The counter autmoatically resets to zero once it reaches the end.
i guess a latch circuit is in order . . .
Bjørn
Sat Mar 01 2008, 10:29PM
To count 15 events you could start it at 1, but if you are using the bit patterns for a display then it would not help.
Ken M.
Sun Mar 02 2008, 12:56AM
Just for reference I used a display so I could make sure my concept was right, since I was using my simulator. Evr, even though your looking for the fewest parts and simplest setup, this would still be 2 ic's the lacth and the 74161. Heres the counter with a latch.
1204419297 618 FT40285 74161 Counter
With this it'll get to 15 and reset, then just hit the reset and it'll start counting again. Unless you already figured that out.
Sun Mar 02 2008, 02:56AM
Thanks for all the help. That J-K latch should definitely do the trick. I'll have to simulate a bit to make sure, but i think it will do!
Thanks again
Ken M.
Sun Mar 02 2008, 03:23AM
It works fine, I tested it on my simulator, tongue , and it works, as for actual part numbers its upto your discretion, the values I used where just what the simulator gave me, I probly could have chosen a different part number but Here it just changes switching speed and such.
