  • Guests: 42
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Electromagnet Design for Magnetic Levitations
Derrick
Sun Feb 24 2008, 09:13AM Print
Derrick Registered Member #1350 Joined: Sun Feb 24 2008, 09:07AM
Hi all,
I am currently doing my final year project and need to design an electromagnet out of an iron core bar. The magnet is used to levitate an object (approx 2kg) mounted to a permanent magnet. I am stuck at the calculations part on design this electromagnet to suit this 2kg object. What are formulas I need to apply for these calculations? I sincerely appreciate any advices. Thanks.
Regards,
Derrick
Bored Chemist
Sun Feb 24 2008, 09:51AM
I guess you realise it depends on the strength of the pemanent magnet. I sugest you look at doing some smaller scale experiments with smaller coils and weights first.
Sun Feb 24 2008, 10:55AM
I have forgotten the formula but it's something like F = k.A.B^2, can't remember the constant k.
B is actual flux density, not Bmax for the magnet, you will have to solve the magnetic circuit to determine B.
A is the area through which B 'flows'.
Must be somewhere on the net.
Tesladownunder
Sun Feb 24 2008, 11:41AM
There must be a height measurement that they want you to solve for, because at 1mm you only need a small chunk of iron core and no electromagnet for it to elevate a reasonable NIB permanent magnet and 2kg. At 5cm it is another story and I need a several square inch core cross section to support 200g at 70V 2A or so.
TDU
Derrick
Mon Feb 25 2008, 01:29AM
Is there any websites or books which can show me the formulas for designing this electromagnet. The sites I been to are only showing brief descriptions of the levitation kits. I need more in depth details. Thanks
