  • Guests: 31
GPS patch antenas
Sun Mar 12 2006, 06:48PM Print
I have been using a small patch antenna for my rocket gps tracking, but it recently broke (a hard lading sent the antenna flying out, which ripped of the connector--probably could be fixed but I decided ot shell out the $20 for a new one). So the new one came, and I noticed that the ceramic? block of the new noticeably lighter in color than the new one amazed
Is this from exposure to water or something? Just wondering, not sure if it is a bad thing or not... I would do a side by side test to see if the range suffered, but don't want find a way to connect the old one to the gps module.
If anyone wants the old antenna... It is just a small patch antenna with an internal 3.3v amplifier and a 3" piece of coax hanging out designed for a Lassen IQ gps...
Mon Mar 13 2006, 12:36AM
Unlikely, probably a different ceramic.
-A
Mon Mar 13 2006, 12:47AM
Do you think that they vary that much from batch to batch? Seems like they would keep tolerances pretty tight on an antenna/amp with a sensitivity of -150db...
