  • Guests: 25
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
ATX Lab Supply
rp181
Thu Feb 21 2008, 01:03AM Print
I got a ATX power supply from someone and im trying to use it as a lab supply. I searched the number and got this:
wich is what i have. Im not able to turn it on now. I tried Green to black already, and the only thing that happens is there is a "squeaking" every maybe 1 second. The noise stops when i take the green of the black.
How can i turn it on?
I also tried it with a minimum load, being a 10W 10 ohm resistor connecting red to black.
cjk2
Thu Feb 21 2008, 01:30AM
It might need more than 500ma of load on the 5v line, try using that resistor on the 12v line. Also, take it apart and check for any bad caps, they fail all the time in these.
rp181
Thu Feb 21 2008, 01:33AM
i did take apart, how do i check for bad caps? will top just be boke? There is one small ceramic cap on the heatsink, mabey that failed?
Ultra7
Thu Feb 21 2008, 02:15AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Try this.
rp181
Thu Feb 21 2008, 02:21AM
I saw that before, and the resistor on 12v line didnt work. I have the same resistor he uses and tried across 5v line and 12v line.
Thu Feb 21 2008, 04:29AM
You might try plugging in an old hard drive to it, sometimes that help them run.
Another thing you might be having trouble with is that some high end supplies have a monitor line that is in one of the 3.3v and 5v pins of the 24 pin connector, which would need to be connected to their respective buses (these lines should be noted on the label, no guarantees tho).
You have checked that it is set for the correct voltage...
It is also possible that the supply is dead to start with...
Wirenut
Thu Feb 21 2008, 06:14AM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
Compaq power supplies use a proprietary pinout. Link2
Try pin 16 (white) to ground.
rp181
Thu Feb 21 2008, 01:47PM
i tried, doesnt do anything. When i touch green to the black and white and take the white off, the fan turns a little.
I also tried with resistor connected to brown and ground and red to ground.
cjk2
Thu Feb 21 2008, 10:54PM
If you cut the ATX motherboard connector off, you will need to make sure the small brown wire is connected to an orange wire, it doesn't matter which one you pick. Look for discolorations on the PCB, as these can show that something overheated. Caps that are bulging at the top can be assumed bad and replaced.
rp181
Sat Feb 23 2008, 06:33PM
I think that there is 3 voltage sense wires. When i connect it, it gives power o a motor. The problem is that the internal fan doesnt on, and when i connect it to the electrolysis cell, it pulses .5A through it. The cell resistance is one ohm.
