  • Guests: 44
electrical --> mechanical "switch"...
SkullCurrentResistor
Sun Mar 12 2006, 04:02PM Print
SkullCurrentResistor Registered Member #308 Joined: Sun Mar 12 2006, 03:30PM
Hi
Okay, ive been puzzling with the idea of building my own RC model plane for some time and i have begun the construction, or rather the theory of construction, but:
its electrical controlled, and the fins and flaps are mechanical, i dont know how they normally construct this, ive never looked inside a working RC airplane. but it would have to be a small and light solution right?, and im thinking step-motor confused but thats still too big right?
what kind of mechanism could be used here? confused
the_anomaly
Sun Mar 12 2006, 04:11PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
A "servo" is used. Its kinda like a small stepper motor. What size plane are you thinking of building?
Sun Mar 12 2006, 04:26PM
i was thinking along the line of 60-80cm in length and wings to match that, but it depends on what kind of engines i can get, and such, and what i can afford to buy materials for. It wont nessecary have to be big, but still big enough so i can work with it and still have the desired functions onboard.
Sun Mar 12 2006, 06:41PM
a servo is what is normally used, you can get them in all sises (from ones weighing grams to ones weighing several ounces).
They work by having a small motor (cheap ones use a brushed motor, expensive use brushless) that is geared down to give more torq. But the key part is on the output shaft there is a variable resistor that gives a voltage proportional to the location of the shaft. This goes to a comparator, so that the servo is always where you tell it to go.
