  • Guests: 37
Maths Problem: Matrices
Sun Mar 12 2006, 03:57PM Print
Adam Horden Registered Member #176 Joined: Tue Feb 14 2006, 09:35PM
Hi All,
I have been set a paper on Matrices. I have solved the other questions but stuck on the ones in the url below.
http://www.adamhorden.co.uk/math/math.htm
What methods would I use to solve those equations?
Question 1 I think I need to dtermine the det of A and this is 5 but unshure where to go from there.
Thanks,
Adam
Dr. Shark
Sun Mar 12 2006, 06:10PM
Here you go: plug in A and s into the first equation |sI-A|=0
and do the subtraction to get
det ( s-3  4
      -2   s+1)   = 0
now you follow the usual procedure to evaulate it:
(s-3)(s+1)+2*4 = 0
which simplifies to the result. HTH. If any of this is unclear, please let me know which part troubles you. It is kind of hard to go through this in detail with just ASCII smile
Mon Mar 13 2006, 01:36AM
I am not 100% shure how to go about this.
|SI - A|=0
But what is S?
Can you walk your way thorugh it from start to finish? I have been on it most of the day and still not got an answer.
Adam
AndrewM
Mon Mar 13 2006, 03:05AM
s is a scalar. so sI is simply:
[s  0
 0  s]
Wed Mar 15 2006, 12:20PM
If I remember right, "s" is the wee magic number you use when finding the eigenvalues of a matrix, and |sI-A|=0 is the equation you need to solve to find the eigenvalues of A. You have to use algebra to find the value of "s" that makes the equation true. Or values: there are usually several.
Once you know these values of "s" you can do something else (that I can't remember) to find an eigenvector for each one. Eigenvalues and eigenvectors are important in control engineering, the reason being that if the matrix A describes the dynamics of a system, then each solution to the above equation corresponds to a resonant mode of the system, and the eigenvectors tell you which parts will throb how hard and in which directions.
For instance, if you write the circuit equations for a DRSSTC and solve them using this method, you should find two solutions to the equation.
Thu Mar 16 2006, 02:03PM
Steve Conner wrote ...
Hi Steve,
Yes matrix algerba is inportant in control systems and this is what I am studying at the moment.
I handed the paper in tuesday after solving for S and solving the equations etc but my leacture said he would just be happy with:
Write the matrix in the form:
A  B
C  D
The determinant is calculated with the formula:
 (ad) – (bc)
Adding information into the formula:
((s-3)* 2) – ((-4)*(s+1)) = 0
Simplifying the formula:
Multiplying out the brackets:
(S2 * -2S) + 5 = 0
This proves that the determinate = 0.
S is a Eignevalue in control engineering and thats where my confusion was. After chatting to him he realised that he should of changed the letter as the text books we follow discuss eigenvalues and S is defined as a constant when working out eignevalues.
I was expecting to have to solve a larger solution but he just wanted a proof of algerba techniques and using determinants.
Thanks all for the tips,
Adam
