  • Guests: 34
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Final Electrolysis Post :)
rp181
Mon Feb 18 2008, 02:22PM Print
I got around to making my final electrolysis set up, but i have 1 problem. Im using 2X4 inch plates, total of 6. The base is NaOH in housed in 3in PVC. When i tried running it for more than 10sec, the foam starts coming up through the tube and into the bubbler. How can i get rid of the foam? The main chamber has a Ping Pong ball and a grid right before the tube opening. It has a good enough prodeuction to produce a HHO flame (yay :)), but i dont want my electrolyte wasted into the bubbler tap water.
Heres a labled Overall Picture:
1203344567 1062 FT0 Dscf0089
Mon Feb 18 2008, 04:30PM
This is a common problem in electroplating where anti-foaming agenta compatible with the electrolyte are used to solve the problem.
rp181
Mon Feb 18 2008, 05:41PM
im not able to buy anything atm, but is there a homemade option? i read NaOH is used to make soap, so im suspecting some grease or oil got in it, making soap. Filtiring hasnt done anything ;(
Mon Feb 18 2008, 07:49PM
Hot, strong, NaOH solution will etch some plastics.
Why not take some of the solution that has been foaming, and evaporate to dryness, which may reveal contaminants or undesirable reaction products not present in the starting solution?
rp181
Mon Feb 18 2008, 09:00PM
Im preety sure itle be fine, PVC is used in plumbing after all. Ile never be letting it get hot.
What do you think of coffe filters? How long would it last if i put several layers?
Mon Feb 18 2008, 10:39PM
A 50% solution of NaOH at 66 deg C will cause severe attack and penetration of PVC, but have no significant effect at 22 deg C.
A 10% solution will have no significant effect at either temperature.
Source: PVC CHEMICAL RESISTANCE GUIDE
A stainless steel sieve or gauze might help to break up the foam. You'll just have to try it and see!
