  • Guests: 26
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Inducing a current in a coil
Sat Feb 16 2008, 10:55PM Print
A magnetic field moving perpendicular to a coil of wire will induce a current. Now I have many coils around a laminated core of iron. Is there any difference in the voltage induced, other than the added volts per turn, if the outer diameter of the coil is close to the diameter of the laminated core, or if there are so many turns that the laminated core diameter is small compared to the diameter of the coil?
I guess what I am interested in knowing is will the core saturate if the core is small compared to the coil of wire?
Coronafix
Sun Feb 17 2008, 12:07AM
Any core will saturate if you put enough current into the coil.
If you look at the electromagnet in hair clippers it seems that the core is small compared with the windings,
and this is connected directly to the mains, but because of the impedance it only pulls minimal current.
The saturation is a function of flux density, that determined by magnetic flow within cross sectional area, flow being determined by how many amperes per turn can go into a given reluctance.
So it depends on how many amps you pump into it.
Sun Feb 17 2008, 05:15AM
IamSmooth wrote ...
Although the answer might be the same, my question pertains to generation of current, as stated in the thread title, and not the application of current to a coil. What happens to the current induced in coil by a moving magnetic field if the core is small relative to the coil?
I guess another way I could ask the question is if 100 turns around the core results in 100v from a moving magnetic field, what happens if there are 200 turns? Will there be 200v? If I increase to turns to 1000 will there be 1000v? I am not talking about theory where the voltage is proportional to N turns, but in practice where there are a multitude of other factors.
The reason I ask this is because I have a stator where the wire is tightly wrapped around the core. I would say there are about three layers of wire making 105 total turns. I am curious what would happen if I add another 3 layers of wire. Is there a point in practice when adding more turns will not significantly increase wattage as the voltage gain becomes less and the resistive losses increase?
tesla500
Sun Feb 17 2008, 07:12AM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
If you have a core of constant size, and have a certain number of turns of wire around it, and a constant current through that coil, increasing the diameter of that coil won't significantly change the induced flux in the core.
For a shunt wound or series wound brush motor, adding more turns to the stator will increase the flux, up until saturation. This will cause the motor to run slower and produce more torque. It may also effect the ideal brush timing, so may cause more brush arcing.
David
Sun Feb 17 2008, 08:34AM
There are several sub-problems in your question, I'll try to highlight the basic principles that will affect your setup.
For a fixed arrangement of rotor and stator,
the core will be most likely to be saturated when there is NO current in the coil.
As you put amp-turns loading the flux in the core will be REDUCED,
until at a certain amp.turns in the stator there will be NO flux passing through the core within the windings (ideally).
So as you draw more current the voltage will reduce.
Adding more turns will give proportionately more volts and less amps.
The short answer is - you can't get more electrical power out than you put mechanical energy in.
The number of turns determines high voltage at low current for many turns
OR low voltage at high current for many turns.
But the direct answer to your initial question is that adding more turns will not affect core saturation.
