  • Guests: 28
rev (49)
Cheech707 (35)
M_Gargantua (35)
nyditch (39)
07/20 rev (49)
07/20 Cheech707 (35)
07/20 M_Gargantua (35)
want to make vacuum tube triodes.
Fri Feb 15 2008, 07:40PM Print
well i have made one but i need to know were i can get a powerful enough pump.i have some mesh and i would like to make a big tube capable of a few 1000 watts plate powwer.........i know this may cost alot and since i have 10$ a week income:P....but anything that would work i will save up for :)
Experimentonomen
Fri Feb 15 2008, 08:15PM
First of all you need a dual stage rotary vane fore pump, then either a oil diffusion pump or a turbomolecular pump.
With your week income i estimate it´ll take you around a few years to save up to only one of the two needed pumps.
Fri Feb 15 2008, 09:27PM
I don't mean to discourage you, but all the equipment and workshop facilities you would need to pump down and outgas a big glass envelope, construct and seal in the electrode structures which have generally to be made of troublesome refractory metals and so on, would cost you very much more than buying a large transmitting triode. I have seen surplus valves of that size from broadcasting transmitters on sale for £100 - say US$200 - much, much less than you would have to spend to construct a large triode valve that actually worked and did what you wanted it to!
Coronafix
Sat Feb 16 2008, 01:15AM
Check out the video.
Chris
Sat Feb 16 2008, 03:33AM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
It helps to have an alkali metal scrubber, too.
Shaun
Sat Feb 16 2008, 04:44AM
Making those tubes requires a HUGE amount of glassblowing experience which would probably take years to acquire, not to mention a facility equipped to do it.
Sat Feb 16 2008, 07:40AM
ok i see i will not be doing this.thanks guys!
c4r0
Sat Feb 16 2008, 12:24PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
There's one guy here in Poland who makes vacuum tubes at home. He has a lot of vacuum equipment indeed, however he made many tubes (triodes, nixie, VFD, even working GM-tube) in his kitchen. Check Link2 and Link2 wink
Sat Feb 16 2008, 01:04PM
Needless to say there are active devices which anyone can make at home with very little in the way of money and equipment.
With nothing more than a scrap of galvanized sheet metal you can make all sorts of oscillators, amplifiers and even a transmitter with a home-made negative resistance device. See Zinc Negative Resistance Oscillator here:
Maybe not quite a costly mega triode needing a giant power supply, but great fun all the same!
Myke
Sat Feb 16 2008, 04:58PM
I made something like this. It's pretty easy but finding the right spot can require some amount of patience.
