  • Guests: 53
Chinese caps for marx generator ??
sparky99
Fri Feb 15 2008, 06:23PM Print
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
Lots of HV caps popping up on eBay lately. Anyone used these Chinese caps in a Marx generator ? Do they hold up ?
Thanks,
bob
Sparky99
CompWiz
Fri Feb 15 2008, 10:29PM
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
I hope there good because I just bought 40 of them for a Marx...
Fri Feb 15 2008, 10:52PM
I have twenty of the 2n2 20kV ebay Chinese ones in a Cockcroft & Walton generator where they have been reliable to date - though I shouldn't want to run them without dielectric oil as the leads are set quite close together. I bought a batch of 30kV PIV 10mA rectifiers from the same source, and they too have proved good so far.
sparky99
Sun Feb 17 2008, 03:05AM
Thanks for the replies! Will go ahead & place a bid.
Bob
Sparky99
Andyman
Fri Feb 22 2008, 07:07PM
Are these the ones you guys are talking about?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=150209526757&_trksid=p3984.cWAT.m240.lVI
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=150209526376&_trksid=p3984.cWAT.m240.lVI
They would make for a pretty darn small MMC. Probably of only 2 or 4 caps. I don't know if I would trust them, though. They're a little cheap. Amazing1.com has .02uF 10kV tesla coil capacitors for $230! The Chinese ones are .02uF 15kV and only $15.
Fri Feb 22 2008, 07:53PM
I've bought both diodes and capacitors from this Chinese firm and found them to be good.
Why pay over the odds for something 'amazing' when you can get standard parts from a source close to the manufacturer? No one could ever afford to make anything at the 'amazing' price!
CompWiz
Fri Feb 22 2008, 08:25PM
That is the same seller I bought my stuff from...
I don't have them yet tho so I cant say how good they are
I ordered these: Link2
jpsmith123
Fri Feb 22 2008, 10:07PM
I wonder how well these polypropylene caps will hold up under high pulse current conditions? I see the 15kv 0.02uF caps for example have a spec of: "Ip-p = 130A". That doesn't leave me feeling warm and fuzzy about the tens of kA or more they may see in a marx generator.
Sat Feb 23 2008, 10:02PM
I bought 20 capacitors which were equivalent to those, CompWiz, only mine were 470pF. I just (today) used all of them in a bipolar Marx generator which seems to be working well. The only problem I had was from the capacitors arcing over, which was easily solved with some epoxy. Rated for 15kV and only 1cm between the leads. ill I wouldn't take them over 10kV.
Penguin has made a Marx generator from cheap Chinese caps as well. Link2 So they are tried and true.
CompWiz
Sat Feb 23 2008, 11:49PM
I had some 10kv caps that likes to arc over too.
I think I used hot glue to stop it.
