  • Guests: 62
Simple DRSSTC
Linas
Fri Feb 15 2008, 06:53AM Print
Hi
I want to make small, something like 20-50cm spark generating DRSSTC, i have STGW30NC60W IGBT ( they are good for DRSSTC? )
Does necessary use over current protection is small DRSSTC ?
Tank cap will be 50nF 20KW ( i have ftoroplast cap's), and what kind of schematic use ?
i thinking about this one :S Link2
Coronafix
Fri Feb 15 2008, 07:35AM
Well if you check out this thread Link2 you will see what that schematic can do. cheesey
Linas
Sun Feb 17 2008, 06:08PM
Hey cry , no one what to help me cry
Does full-bridge is beter what minibruite configuration? (about IGBT )
And 20kV 50nF is good cap for my setup ??
And Vgs for my IGBT should be 20V or 15V ?
And with my IGBT current limiting set to 200A ??
And feedback xformer should be mounted on secondary or primary ? mad
please help rolleyes
Coronafix
Sun Feb 17 2008, 11:06PM
You should just ask the guys in that thread, they have built, are building them, so theres a lot of
experience on Dans design there.
Austin
Sun Feb 17 2008, 11:37PM
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
yup and i check that thread just about every day :)
Dr. Drone
Tue Feb 19 2008, 04:12PM
shades
Linas
Wed Feb 20 2008, 08:49AM
What about IGBT Vgs ?
use 15V or more (because Max Vgs is +-20V) rolleyes
Crow187
Wed Feb 20 2008, 02:46PM
Crow187 Registered Member #795 Joined: Mon May 21 2007, 06:04PM
If Vgs max is 20V than I would use 20 V!! But be shure that the voltage is limmeted to 20V by zener diodes or something like that!
Linas
Thu Feb 21 2008, 07:57AM
can I use PLL driver for DRSSTC ? because i have nice on PLL driver,
he have current x former and two different enable functions, bun tot synchronized frown
1203580665 1143 FT39073 P1360646
Can for DRSSTC test use SGTS Tesla coil primary and secondary ?
65cmx16cm secondary 0,5mm wire 113KHz F resonance
primary 4mm 14 turns
(sorry for double posting frown )
1203609890 1143 FT39073 Sstc
