  • Guests: 66
flyback driver problem
teslacoolguy
Thu Feb 14 2008, 10:27PM Print
i built a simple 555 mosfet flyback driver today Link2 to rig up to an ac flyback i had bought for a plasma globe it worked very well except i noticed i was getting a lot of feedback voltage back into my power supply spikes up to 50v with 18v input and i wanted to know how i can stop that from happening.
Myke
Thu Feb 14 2008, 10:33PM
Put in zeners, inductor, or MOVs?
I think the inductor and/or zener would be the best because the inductor would help supress the spikes and the zener would clamp the voltage across the power supply.
Am I right in thinking this?
teslacoolguy
Fri Feb 15 2008, 12:57AM
ok i will experement with some inductors and i will test it with some 12v zeners and see if that works
Fri Feb 15 2008, 07:13AM
Use a big filter capacitor (few 1000's of uF)
Tonic
Fri Feb 15 2008, 12:02PM
jmartis wrote ...
That reminded I've had in my mind a question regarding smoothing capacitor. Is there a rule of thumb for ratio between capacity and amperage? I mean, how much Farads are more than enough for, let's say, 1A?
TheMerovingian
Fri Feb 15 2008, 01:22PM
No it depends or current rating and internal ESR. Capacitors can tolerate a certain amout of ripple current depending on the type, thermal rating (eg 85 vs 105) etc. You should browse the producer pages for datasheets
Fri Feb 15 2008, 02:21PM
Tonic wrote ...
jmartis wrote ...
There is generally said 1000uF for every A but of course its dependent on voltage...
Tonic
Fri Feb 15 2008, 03:36PM
jmartis wrote ...
What do you mean?
Fri Feb 15 2008, 05:56PM
Tonic wrote ...
jmartis wrote ...
What do you mean?
I just heart that somewhere, that for "normal low" voltages (I would say in the range 12-50V), use 1000uF for every amp you are drawing.
Of course it would be better to calculate the ripple and decide how big ripple your circuit will tolerate...
teslacoolguy
Wed Feb 20 2008, 04:06AM
ok i fixed the surging problem but now i ran into another problem. when i swapped the ac flyback with a dc flyback everthing worked absolutely fine so i decided to audio mod it with pin 5 on the 555 and it worked very well for about 15s than all of a sudden it started to draw alot of amps so i shut it off thinking i blew the fet. but nope that was not the problem the fet was fine but now it is drawing way to many amps than it should. before this happened it drew around 800ma now it is drawing 3A easy and it is driving me crazy why it started to do that.
