  • Guests: 35
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Inverting class b push-pull?
flannelhead
Thu Feb 14 2008, 04:35PM Print
Could an inverting class b push-pull amplifier done like this or is there some reason why it can't be done?
Thu Feb 14 2008, 05:05PM
i have always wondered if i could do that with mosfets so i could drive a sstc better
Thu Feb 14 2008, 05:31PM
spark wrote ...
Pull
It would only work if you included base resistors, otherwise the transistors will short out the power supply through their base "diodes" and be destroyed.
cbfull
Thu Feb 14 2008, 05:36PM
Don't PNP transistors generally have poor characteristics when used in higher power applications?
