  • Guests: 42
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Polishing small heat-treated parts
GimpyJoe
Thu Feb 14 2008, 02:14PM Print
My dad needs some small steel samples polished so he can measure cracks in them under a microscope. To do that, I've been wet-sanding them and polishing them with progressively finer grades of sandpaper, but because of the pitting from the hardening process it takes for ever to polish just one piece. I want to build a device to take some of the work (and finger pain) out of this.
Maybe an abrasive tumber? Or a small random-orbital sander? Any ideas?
cbfull
Thu Feb 14 2008, 05:39PM
I have heard it is common to use a "Vibrating Polisher" for small parts. Many people use them to polish screws, bolts, car parts and such. Polishing pinballs is one popular use for them. Try googling that name and you should get loads of sites.
Coronafix
Fri Feb 15 2008, 01:27AM
How about a Dremel with a polishing tool attached?
GimpyJoe
Fri Feb 15 2008, 04:43AM
I think I'll try the vibrating polisher since even if it works slowly I can just leave it for a while.
My dad tried dremeling them but it apparently didn't work. I'll have to ask him why.
Billybobjoe
Fri Feb 15 2008, 05:33PM
There are usually a ton of 3lb. capacity rock tumblers available on eBay made popular for use as ball mills (in the pyrotechnic field). I've used mine to polish small oddly curved silver pieces for a sculpture and it worked nicely. I used sand, water and a bit of soap - obviously depending on how fine of a finish you want you can get different grits of sand.
