  • Guests: 29
Weston (30)
TheMooseGoesMoo (33)
09/24 Rollingblackout (50)
09/24 ScottyNZ (47)
09/25 KresoLiubov (40)
Using aircored inductors in boost converter
TheMerovingian
Thu Feb 14 2008, 11:25AM Print
I'm currently working for the ICCOM-CNR institute as a local sponsorship working on fuel cells. In particular I use some electrochemical methods to test catalists for DAFC. Having also a small background in electronics i design some power converters to power small devices from fuel cells (eg cell phones) with the purpose of attract fundings and investors showing some applications at congresses and fairs. Fuell cell stack voltages are very low, so i switched on controller ICs (Maxim) that require small voltages to work with bootstrapped output. Since the voltage is very low (0.9 - 1.5V) and the swithching frequency is insanely high (1MHz) i need a very small inductor with a high current rating (>2A). The inductor value ranges from 0.5uH to 1.5uH . I failed to design properly the inductor using a ferrite core, and the commercial inductors have a small current rating and are difficult to find here. I was suggested to try air core. My worries are that an air cored inductor at 1MHz will radiate noise all other the place and so have poor efficiency. So should i try air core or buy an appropriate inductor from eg CoilCraft ?
Mates
Thu Feb 14 2008, 11:57AM
TheMerovingian wrote ...
What about to load 10 electrolytic caps to 1V in parallel and then reconnect them electronically in series and load a one cap for 10V? That could be much easier to construct…
GeordieBoy
Thu Feb 14 2008, 12:18PM
Although the inductance value is low, the air core coil may still be quite large and need many turns.
You could try air-core, ferrite stick, iron-powder and maybe even a small gapped ferrite core design. You didn't say what the design constraints were, eg. Cost, efficiency, weight, temperature rise, EMI? A design using a ferrite stick or a tiny gapped Mn/Zn ferrite core set should give lower overall losses if done properly. You could also try winding the choke on a type-2 iron powder core from Micrometals. Something like 19 turns on a T30-2 should be close to 1.5uH and not too lossy at 1MHz.
All designs but the iron powder one will have a significant leakage field.
-Richie,
Thu Feb 14 2008, 06:54PM
If I were you I'd design my inverter to operate somewhere between 280 kHz and 530 kHz,
above the LW and below the MW radio bands - less chance of consumer complaints.
If so then I'd go for a ferrite LBC (large-bobbin-core) inductor if you're desining a trough-hole pcb.
They're cheap, about the size of a 0.5W resistor, can handle fairly high currents and have a reasonable 'Q'.
e.g. Link2
If you're designing smd then there is a huge range to choose from.
Assuming your design(s) will go into production, start with components suitable for mass-production.
Marko
Thu Feb 14 2008, 07:08PM
Hm, isn't it important which mode converter is designed to work in,
as far as I know powdered iron is not good for large AC components but is superior to ferrite in max flux density (which you may not need much at all) so it would be a choice for a continuous mode converter. And yes, toroidal cores with distributed airgap will leak less flux.
From other side discontinuous mode converter would need ferrite core because of large AC component, may have more loss due to skin effect, but efficiency of circuit is helped because of zero current turn on, and etc.
As usual it's lots of trade offs, I hope you guys fill me up if I'm wrong on something.
But I don't see a special reason why would you want to use air core if you don't need to, as it will always have lower efficiency per cost that cored inductors.
Can you describe how did you exactly 'fail' it, how was the core dimensioned and gapped, more data?
Just few turns would in most cases be enough for what you described.
TheMerovingian
Thu Feb 14 2008, 10:45PM
Marko wrote ...
I cannot calculate a proper value, since i don't know ferrite permeability.
Design a 1.5uH air cored inductor isn't tricky, but i don't know if i has some drawbacks
Dr. Slack
Sat Feb 16 2008, 06:58PM
You don't need to know the ferrite permeability to design a flyback inductor to specific inductance.
Think about it.
If you are designing a flyback inductor, then it needs an air-gap, otherwise you are wasting almost all of the performance of the ferrite.
If it has an air-gap, then the air will dominate the ferrite (if you've designed it right), and to a first approximation you can consider the ferrite as infinitely permaeable.
As a small correction, reckon the total ferrite path as 10% of the reluctance of the airgap. It's probably in the right ball-park, and won't make a huge difference if you're wrong by a factor of several either way.
An air-gapped ferrite will give you best volume efficiency, an air-core would need to be big to compete on Q, and a non-air-gapped ferrite would use much ferrite and be very inaccurate.
