  • Guests: 27
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
two induction heaters.. will it work?
PAVALOS
Thu Feb 14 2008, 07:10AM Print
PAVALOS Registered Member #1042 Joined: Thu Oct 04 2007, 08:06AM
Hi all
I was thinking if i take two induction heaters not so powerfull and place them together
with two same coils combined, will it heat a screw faster?
Tonskulus
Thu Feb 14 2008, 09:25AM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Yes, but in practice, those induction heaters should be synchronized so that both coils are in phase. If one coil is 180 degrees out of phase compared to another, there is no heating effect. But im not sure if merging two coils together is reasonable.. If it would be possible synchronize those two inverters, then it would be (in some case maybe) possible to connect two heater supplies in series configuration for driving single workcoil with double voltage.
PAVALOS
Thu Feb 14 2008, 09:55AM
I will try two zvs heaters to see the results ;)
Tonskulus
Thu Feb 14 2008, 11:52AM
Now what is the point anyway? You just cant merge two separate workcoils with separate zvs drivers..it doesnt work that way. If you need more power, you should increase input voltage for ZVS to get some more heating power.
PAVALOS
Thu Feb 14 2008, 12:13PM
You re right
