  • Guests: 66
i cant get zvs flyback driver to work!
Tue Feb 12 2008, 12:08AM Print
i tried it twice.still wont work :(.i think its from the fast diode.is 30ns good enough?the diode is bym26c.the capacitor i used was 1uf from a microwave oven.i used irf640's.and can i use two different mosfets?
Shaun
Tue Feb 12 2008, 02:08AM
I don't know about your diodes, but the fast diodes in the schematic don't really have to be that fast. 1N4007s will work too, but I still use UF1005 to be safe.
The HV capacitor from a microwave is a bit overkill as far as voltage goes, but its a film cap and should be OK.
IRF 640s seem OK for ZVS, just don't push them too hard as they are only goos for half the amps of IRFP250.
And NO NO NO you cannot use two different types of MOSFET!!!!
Myke
Tue Feb 12 2008, 02:24AM
I'd say make sure you got the connections to the MOSFETs correct and also double check the polarity of the diodes and the pins they go to.
Tue Feb 12 2008, 02:54AM
thanks for the help but it is not working
Avi
Tue Feb 12 2008, 03:08AM
make sure the primary coil is ALL wound in the same direction and just center tap it (2 coils in the same direction and join the middle leads)
Shaun
Tue Feb 12 2008, 03:52AM
No offense to you, but we are going to need a little more than just "its not working" . There are some common problems like primary phasing and the polarity of various components, but a few pictures will work wonders.
What kind of inductor are you using?
Have you made any other changes to the schematic other than the irf640s?
What is your power supply and the voltage it produces?
Tue Feb 12 2008, 05:01PM
is the inductor absolutely necessary?and do the zeners have to be 12 volts?i think i fudged up all over the place.srry to waste your time but i have only been doing this for a few years.and me being 14 i really cant get everything i need.............................................. ......this is were everyone stops helping me..
Tue Feb 12 2008, 05:09PM
1) yes you need the inductor and it should be of the right material (powdered core or gapped ferrite) and enough inductance. 2) the zeners can be anyting 12-18V and enough watts (I would suggest, get at least the 2 watt ones) 3) If you build it with the parts as in the schematic it should work on first turn-on. smile
Tue Feb 12 2008, 05:13PM
here is some pictures having to do with the zvs flyback driver.
1202836401 1225 FT38880 Zvs Driver Not Workn 00
Tue Feb 12 2008, 05:14PM
oops...here is the other picture
1202836456 1225 FT38880 Zvs Driver Not Workn 00
