  • Guests: 63
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
DC power supply question
magnetomotive
Mon Feb 11 2008, 08:59PM Print
magnetomotive Registered Member #267 Joined: Mon Feb 27 2006, 09:44PM
I have a DC power supply that has the output wires exposed. There is a white wire and a bare copper wire. I need to know for sure which one is ground (negative) and which one is hot (positive), but I do not have a multimeter to test this.
My first thought was that white is the positive wire. Is this correct?
Mon Feb 11 2008, 10:34PM
Assuming this is a relatively low voltage DC supply, then it should be safe to do the following
Extend your unknown wires, bare them at the very ends, and stick them in a glass of strong salt water made with ordinary kitchen salt. Take care you don't let the wires touch together which might damage your supply.[secure them with clothes' pegs etc to stop them wandering about in the glass] In a very short time you will begin to see:
Yellow-Green bubbles of chlorine gas forming at the anode (+) and colourless bubbles of hydrogen rising up from the cathode [-]
Myke
Mon Feb 11 2008, 10:50PM
If you know the output voltage then you can connect a LED with an appropriate series resistor to see what is positive and what is negitive.
magnetomotive
Mon Feb 11 2008, 11:46PM
Thanks for the suggestions. However, I do not have an LED or a resistor available, and the salt water idea does not sound safe at all.
It is a 12V supply rated at 10W. I was simply wondering if anyone here was familiar with wire color codes for DC supplies. I could not find a definite answer by searching google.
Tue Feb 12 2008, 12:27AM
On the scale of things in this forum, you're not really likely to come to any great harm putting a pair of electrodes at 12V into some salt water, but you know your own situation better than I do!
rp181
Tue Feb 12 2008, 01:19AM
put the wires in weak salt water and the one with most bubbles is -. Wont produce much chlorine and the chlorine that does come will probably dissolve in the water.
Capper
Tue Feb 12 2008, 01:32AM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
There's no such thing. Every shop, every industry, even every country has their own color code standards, and none of them follow them. In the US, {most of the time, or some of the time, or sometimes} red wires are positive and black wires are negative, and bare copper wires are either a neutral, ground, or a shield.
We had a German intern here for a while, and his color code was red for negative, white for positive, and black was something else - caused quite some trouble while we were building test stands.
If you have co-axial cable, and the bare copper is wrapped around the white center wire, then I would assume the white wire to be the positive one. The LED test is a good one I use most of the time myself when I can't get to a volt meter.
Another trick is to use a small DC motor (or PC fan) and hook it to a known voltage like a 9V battery and watch what direction it spins, then put your power supply on it and watch what way it spins.
C@P
Shaun
Tue Feb 12 2008, 02:01AM
The salt water idea is totally safe. The one that bubbles will be negative.
I think that if you are going to work on any type of electronics you should at the very least have a multimeter. It would make this a trivial issue requiring less than 5 seconds of your time. They can be had for $8 or so at places like hardware stores, radioshack, hell I've even seen 'em at Kmart.
Tue Feb 12 2008, 03:19AM
magnetomotive wrote ...
There are no universal color codes when it comes to supplies like that.
As others have said, you have several suggestions:
1) Get a cheap multimeter - you can get one for about $5.00 at radio shack
2) Get an LED - about $0.10 or you can probably find one
magnetomotive
Tue Feb 12 2008, 03:37AM
Thanks for the help everyone. The wire is a coaxial-type like Capper said. The bare wire was ground.
