  • Guests: 54
Barry (71)
Snowcat (38)
wylie (44)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
power calculations
teslacoolguy
Sat Feb 09 2008, 03:58PM Print
i am planning to make a 2.5kj capacitor bank for a can crusher. the capacitence will be 7800uf at 800v and i cant find a formula to find how many amps that will be because i need to find an appropriate scr to withstand the surge and was wondering if anybody has a formula to calculate that.
TheMerovingian
Sat Feb 09 2008, 05:11PM
The surge current depends on 1) capacitor ESR 2) connections resistance and inductance 3) Coil resistance and inductance. You should get these values , use an RLC simulator and then get the peak current and overrate it of 50% to calculate the needed SCR. Also remember to use antiparallel diodes to protect your caps from reverse charging.
PS: this should be posted in HIGH VOLTAGE section
ramses
Sat Feb 09 2008, 09:24PM
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
the diodes that they sell at radio shack can't take this kind of abuse. especially if they decide to conduct backwards. so buy yourself a bridge rectifier on ebay and use a leg, 2 or 4 of that instead. I found out the hard way
teslacoolguy
Sat Feb 09 2008, 10:41PM
im not worried at all about the diodes i bought a 1ka surge diode from newark that im going to use so i should not have any problems at all
Sun Feb 10 2008, 05:03PM
A simple RLC calculator here will let you try some values. Spin the inductance dial until you get the timing you want, and assume near-zero resistance to find the theoretical maximum peak current for a given LC circuit. Now if only we could actually build a zero-resistance coil ... cheesey
Let me know if there are any technical problems in the simulator.
Cheers, Barry
teslacoolguy
Sun Feb 10 2008, 09:55PM
ok im having a bit of trouble. i have no idea how much inductance or resistence a couple turn coil will be for a can crusher and i am getting readings up to like 70ka and i know that is way out of the ball park so im a little confused
Tue Feb 12 2008, 03:41PM
heh, welcome to the electromagnetic design process. You have the capacitor and you're trying to figure out the requirements for the coil and switch, both of which depend on each other's design.
Since you have some idea about what size coil to use, I suggest that you estimate its resistance and inductance using a coil calculator like this one.
This will get you started but it's pretty rough estimate -- your coil is only a couple turns and the other wiring can have a significant effect on the actual values.
Keep in mind that 2.5kj is a heckuva lot of energy into a few inches of wire that represents almost a dead short. So I would expect that 50 - 100kA is not unreasonable. Indeed it's the whole point of your circuit as you want as much surge current as possible in a can crusher. cheesey
Cheers, Barry
I'm thinking: What would Scooby do?
ramses
Tue Feb 12 2008, 08:08PM
well good luck finding a 100ka SCR... for that reason, I would use a trigatron (triggered spark gap), or an open air mechanical switch. fastmhz's 24kj cap bank thread has a few links, as well as pix of the trigatron he is using. if at all possible, I would go for a slightly higher voltage like 1.2kv to achieve the fastest possible risetime and biggest peak current.
Quantum Singularity
Sun Feb 17 2008, 02:11PM
Has anyone successfully done a can crusher with lytics? I was thinking the pulse is just not fast enough but not sure. I tried it with my 3kJ lytic bank, ~6800uF, I think maybe up to 1-1.5kJ, and got nothing. Alternatively, my 120uF energy discharge cap charged at 1KJ put a serious hurtin on a can. IDK, maybe I just had a poor coil, I didnt play with the lytic can crushing much.
ramses
Mon Feb 18 2008, 06:18PM
the guy from powerlabs did one, but it didn't work all that well... probably because he used a SCR switch with a 3ms turn on time... use a trigatron!
