  • Guests: 58
Thomas (40)
VulcanBB18 (50)
07/20 rev (49)
07/20 Cheech707 (35)
07/20 M_Gargantua (35)
Problem with Vintage AC meter
Sun Feb 03 2008, 08:05PM Print
I have a vintage 5v AC volt meter for a project. I am measuring the voltage drop across about a 300 ohm resistor. There is an AC and DC component on the resistor, but I am only interested in measuring the AC part. When I use a digital ohm meter with a high impedance I can measure 3 volts. When I connect the vintage meter I read only 2v. When I put the digital meter across simultaneously with the the vintage meter I can see that there voltage is actually under 1v. I guess this is due to the lower impedance of the vintage meter.
In the past I used a capacitor to pass the AC component, rectified the signal and used a vintage DC meter.
Is there anything I can due to fix this problem without using a high impedance meter so the AC meter correlates with the digital meter?
Hazmatt_(The Underdog)
Sun Feb 03 2008, 09:30PM
Do you know anything more about the meter? There are several different types of AC meter available long ago.
The old meter is going to read RMS, but you could convert it to peak readings in a lot of different ways.
1. You could play with a rectifier circuit and see if the meter will respond to DC. This probably won't work very well, but its a lazy approach, and worth a shot because it only takes maybe 10 minutes to rig up. It would sacrifice your input impedance though.
2. An amplifier or buffer
3. A small transformer.
There's probably a few more ways to do it too. This is for only one frequency right? Because if its for a range of frequencies then that is another problem.
What I would point out though is that since your measured value has dropped using a very low impedance meter, the older one, the problem may not be your meter, it might be that your source is being loaded down too much by the meter.
What is the internal resistance of your meter?
3V across 300R, so that's 10mA RMS, 14mA p-p,
and the reading with the old meter is ~1V, so its dropping 2V @10mA, I'm getting 202R as the parallel resistance, approximately.
I get about 618R for the meter resistance, which is pretty low compared to your 3M or 10M input impedance of the modern meter.
