  • Guests: 61
ZVS ignition coil driver!
CompWiz
Fri Feb 01 2008, 05:02PM Print
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
I was reading the archives and seen TDU do something similar.
I wound 5+5 turn on one side of a flyback core and 20+ on the other
and connected that to the coil.
The arcs were VERY small until i increased the cap on the driver to 10uF
EDIT: it worked better at 8uF
the coil only got slightly warm after 5 minutes of fun
As you can see in the video I have corona problems....
1201885343 1038 FT0 Cimg1460
Kizmo
Fri Feb 01 2008, 05:34PM
Impressive!
Sounds like it runs @ very high freq compared 'normal' iggy coil drivers but your arcs are great!
CompWiz
Fri Feb 01 2008, 05:42PM
Got any ideas on how to stop that corona before it makes carbon tracks and arcs over?
Kizmo
Fri Feb 01 2008, 05:51PM
If possible, put it under oil (even cooking oil works but not very long)
CompWiz
Fri Feb 01 2008, 06:05PM
I hate oil... ill try using liquid electrical tape first,
It worked on my marx (until I ran out half way through).
Fri Feb 01 2008, 06:37PM
Drive your coil at less frequency because less frequency means less corona. But this will probably not be possible with your circuit as ferrite cores don't like low frequencies.
If I had to run an iggy coil to get maximum power out of it, I would use a half bridge running at 100-1000Hz.
CompWiz
Fri Feb 01 2008, 06:54PM
there was corona all over the ferrite one time...
I don't know how get the frequency lower. adding more capacitance? more turns on the primary?
Fri Feb 01 2008, 07:44PM
CompWiz wrote ...
you could get lower freq. by increasing the cap but if you go too low, the core will saturate and get hot and you will draw big currents from your power supply.
Maybe you can wind a center tap coil around the outside of the iggy coil and drive it directly but I dont know how well this will work.
Fri Feb 01 2008, 09:49PM
This is a problem I've had with ignition coils..
Since I too don't like oil I used Araldite(TM) epoxy resin adhesive - worked pretty well for quite a long time.
Somewhere around 45 kHz (your coil may be different) the self-inductance of the secondary resonates with it's self-capacitance and the result looks like your video.
Imagine if the capacitance between the inside and outside of the coil-top insulator is 1pF, not much really.
Irms=sqrt(2) x pi x F x Vpk x C = 7 mA rms ! (If Vpk = 35 kV .. reasonable estimate)
Just 1pF will cause 7 mArms of high frequency current to 'flow' through the insulator!
CompWiz
Sat Feb 02 2008, 12:40AM
The liquid electrical tape solved the corona problem!
I changed to cap on the ZVS driver to 8uF and the voltage is higher!
