  • Guests: 46
I built my first Marx...
CompWiz
Fri Jan 25 2008, 11:18PM Print
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
According to my ruler it makes about 110KV!
I used two 10KV 1nF caps per stage
I only have 10 stages so far.
Next time I must eliminate the sharp edges!
the whole room smelled like ozone in 30 seconds, before i covered it with liquid electrical tape.
It took me forever to it firing reliably, until i noticed that my battery was dead.
I also learned that I'm not good at soldering.
How do i stop the negative pin of the flyback from arcing to the core?
it keeps doing it then the switch shocks my finger!!
1201303041 1038 FT0 Dsc00458
plazmatron
Sat Jan 26 2008, 02:53AM
Very Nice! Well done!
To stop the negative arcing to the core, you could always connect it to the core, or ground it, whichever suits.
Keep up the good work!
Shaun
Sat Jan 26 2008, 04:37AM
I had the core-arcing problem when I started pushing too much voltage into my ZVS driver. My solution, indeed the solution to all of life's problems, was to pot the whole thing in epoxy.
CompWiz
Sat Jan 26 2008, 06:27AM
More Pics!
and I added more stages!
grounding the 0v pin made it WAY worse (my finger still hurts)
If you look at it in the dark the cornea is skinny at bottom and HUGE at the top.
its not bright enough to get a good pic even with a 30secound exposure.
Florescent lights glow if I touch them wile I'm stand by it.
Its a good thing I got small caps because my friend stuck his hand in the discharge...
Ill post more pics when I get them off the camera
1201328853 1038 FT38042 Dsc00467
CompWiz
Tue Jan 29 2008, 04:42PM
More Pics!
I don't know why people think tires protect you from lightning...
1201624946 1038 FT38042 Dsc00557
1201624946 1038 FT38042 Dsc00505
1201624946 1038 FT38042 Dsc00553
Hazmatt_(The Underdog)
Tue Jan 29 2008, 07:23PM
Nice Job.
And the tires protecting you, no, its the car acting as the path of least resistance, that's what is protecting you. So you don't get out of the car if there is a power line or lightning striking the car. The instant you do your body becomes a power resistor, not a very plesant thought.
CompWiz
Tue Jan 29 2008, 08:06PM
Like this? Link2
That is one of the resisters I used for my marx connected right to the flyback
Logan Kennedy
Tue Jan 29 2008, 09:04PM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
wrote ...
What's the official stage count now?
Your Marx generator is really cool though. There's ALOT of corona being generated - I would consider encasing it in transformer oil.
CompWiz
Wed Jan 30 2008, 03:18AM
There are 17 stages now.
It will jump about 20cm
The corona is fun to watch in the dark
it looks like lightning going in every direction.
Its arcing around a CD case in the last pic
Video: Link2
1201663104 1038 FT38042 Dsc00526
1201663104 1038 FT38042 Dsc00528
1201663104 1038 FT38042 Dsc00515
CompWiz
Mon Feb 11 2008, 06:01AM
I just bought some more caps off of ebay! Link2
15kv 2200pf
Even with 170kv the sparks seem to small...
so I will build Marx II
I forgot that putting caps is series reduces the capacitance, that is why my sparks are so skinny.
I think I will use the same kind of resistors because they they haven't shone any problems yet.
