  • Guests: 29
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
random stringey smokey stuff from open-air copper mechanical switch?
ramses
Fri Feb 01 2008, 04:18PM Print
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
well i just got a bunch of caps and threw 2 in parallel for 4800uf at up to 300v. hooked it up to my Coil gun and switched with the "touchin' 2 wirez 2gether" method with copper wire and a penny:
this caused a lot of smoke, which went up(smoke tends to do that.)
then a weird stringy thread thing floated down. i recreated the situation and took a picture
I was just kind of wondering what the heck this could be, because it seems to be a solid or a plastic(the state, not the material)that formed from copper vapor. all theories welcome.
since i am retarded, and don't know how to move the pictures(explanation, plz?), they are from top to bottom,
floaty thing
floaty thing (zoomed)
sparks from the shot
1201882401 1208 FT0 100 3440
2
1201882401 1208 FT0 100 3446
sorry about the white border, i can't use paint to save my live!
atomicthumbs
Fri Feb 01 2008, 06:38PM
atomicthumbs Registered Member #498 Joined: Sun Nov 19 2006, 06:00PM
Can you pick it up? Show it in your hand. Does it droop or sag when you pick it up or is it rigid?
Firnagzen
Sat Feb 02 2008, 01:35AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
How heavy is it? Also, what happens after a while? Disappears, melts, etc?
ramses
Sun Feb 03 2008, 04:13PM
I can't pick it up, probably because it is so fragile, but it is VERY light and almost translucent. i can't seem to confine it to see what happens to it, and i end up loosing it after like 30 seconds. I hope that cleared that up.
Sun Feb 03 2008, 06:08PM
Some sort of low density aerogel?
Regards, -A
"Bother" said Pooh, as he realigned the core manually...
Spedy
Sun Feb 03 2008, 09:44PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
0o I;ve read about metal-based aerogels somewhere, it's very cool that you possibly made some w/ such a simple device.
ramses
Fri Aug 28 2009, 10:12PM
super, MEGA bump!!!!
I re-created this burning zinc from pennies in my driveway. here are some better pictures, curves tweaked for clarity.
1251497516 1208 FT38377 Cimg4093
1251497516 1208 FT38377 Cimg4095
big5824
Fri Aug 28 2009, 10:53PM
Is it glowing??? or is that just the flash
Bored Chemist
Sat Aug 29 2009, 08:51AM
Congratulations!
You have rediscovered "philosopher's wool" The light fluffy form of zinc oxide.
MinorityCarrier
Sat Aug 29 2009, 06:35PM
Oh, that stuff.
Mix up a batch of zinc dust and sulfer (60:40) ignite it, and in the resulting yellowish smoke cloud you will see a lot of these.
