How different temperatures of half-bridges in H-bridge affects?
Tonic
Thu Jan 31 2008, 10:39PM
Registered Member #528
The question is simple, we have two half-bridges connected to H-bridge. Each pair of transistors is mounted on untypical radiator and this option will probably cause different temperatures. I don't know how much, but I guess it won't exceed 5*C. How it will affect on efficiency?
Registered Member #162
Shouldn't give any problems so long as each device is within it's specifications. So the overall limit will be when the transistors on the least-good heatsink get hot.
