  • Guests: 48
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Controlling the inductive load
Thu Jan 31 2008, 08:00AM Print
I could make a voltage zero-crossing-detector and make a control circuit that switches a TRIAC for adjustable time before the zero cross, but the problem is that with an inductive load, the current will not cross zero as the voltage does so the control will not be possible from zero.
How should I do it, maybe make a current zero-cross detector instead of voltage? Wait, there's a problem with this, if there is no current flowing to the load I can't sense any current zero cross...
Is it possible to control an inductive load from zero to full?
Slava
Thu Jan 31 2008, 11:16AM
Slava Registered Member #518 Joined: Tue Feb 13 2007, 05:20AM
i would use a mosfet with a capacitive coupler to the line and reference only the voltage, you can always compute and offset the phase if necessary. if you want current you can always use a shunt with a current gated transistor.
Marko
Thu Jan 31 2008, 11:22AM
Those simple inductive-load dimmers use synchronization to mains voltage... It's actually an improvement from current-syncing dimmers, at cost of requirement of one more wire...
Thu Jan 31 2008, 11:34AM
Yes, the phase angle control circuits I've published work fine with inductive loads. Here's my Mk2 circuit controlling a neon sign transformer: Link2
