  • Guests: 28
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
part info
rp181
Thu Jan 31 2008, 01:14AM Print
So today was using a computer power supply to power a magnetohydrodynamic drive. It was working fine, until there was a big flash of light and smoke spwed out of the ventalation holes. I took it apart, and found two of the transistors on the heat sinks melted. Took some parts off and found this:
What are schotty recitifiers used for? Read that it has low voltage high frequency output. Could it be used to power flyback? or any other parts from a computer power supply? It was a 300W ATX supply.
Thu Jan 31 2008, 01:53AM
The diodes serve to rectify the out coming low voltage AC and make it DC, which a minimal voltage drop (about 1/2 a normal diode).
The output of the supply would be great for running a flybakc transformer, you could probably just hook the output to a single turn primary on a flyback and get a resonable amount of power out. Better yet would be to solder a 20ish turn primary directly across the primary of the large transformer in the supply, you should be able to push large amounts of power using that method.
rp181
Thu Jan 31 2008, 02:04AM
The supply burned, im a noob at electronics, can you explain this a little more?
Thu Jan 31 2008, 06:52AM
I tried the method as "..." said, it does not work well... if you just solder the flyback primary to the primary of the xfmr, the arcs are very tiny and the PSU eventually goes to protection mode.
If you remove the xformer, the mains circuit will be left running on the startup self-oscillator (most PC PSUs have this) and you can make bigger arcs from your flyback, but the transistors will get very hot. (if you want to try this start with something like 50 turns on the flyback)
It is much better to build a simple GDT-less halfbridge flyback driver.
