  • Guests: 54
300KV from fly-backs?
Mates
Sun Jan 27 2008, 09:42PM Print
Hi guys,
After I find out principle of modern Fly-back transformer I realized I could have very good use for my collection of these small monsters.
I’d like to start new project and I’d like to get some feedback before.
Here is the idea:
I plan to connect secondary of 5 (or even more) fly-backs in series and make source of very high DC voltage. The primaries will be all triggered by single switch device (IGBT transistor) driven by TL494 oscillating at 20 KHz. I’m enclosing the scheme of the circuit. For single fly-back this simple circuit works very well Link2
Any hints and comments are welcomed…
Useful link (thanks to c4r0) Link2
1201469970 1025 FT0 Sg100882
1201469970 1025 FT0 Scheme
Kizmo
Sun Jan 27 2008, 10:39PM
I have done this with 2 flybacks (look @ my avatar) smile
IMO it is possible to put 3 or 4 flyback xfmrs in series but you will face problems with secondary-core-primary insulation
Mates
Sun Jan 27 2008, 10:51PM
Kizmo wrote ...
I think my design is different from yours because I'm always using the internal primary. I also plan to dipp the whole string of fly-backs in oil bath. However, I still do not understand the insulation problems warning. Each fly-back in the string should face more or less the same voltage stress like when is operated alone. Or am I wrong?
Experimentonomen
Sun Jan 27 2008, 10:54PM
Just try it.
Bender
Sun Jan 27 2008, 11:05PM
Bender Registered Member #1027 Joined: Tue Sept 25 2007, 01:44PM
Mates wrote ...
Kizmo wrote ...
Think about potential differences.. every primary will be ~same potential but secondaries will float way higher than usually when another HV lead is grounded.
Mates
Sun Jan 27 2008, 11:28PM
Bender wrote ...
[Think about potential differences.. every primary will be ~same potential but secondaries will float way higher than usually when another HV lead is grounded.
Shit, now I see it... Would it be a solution to run the whole driving circuit from a battery followed by inverter? (I have one 1500W computer back-up at home)
Mon Jan 28 2008, 08:46AM
Mates wrote ...
Bender wrote ...
If you can find 4 inverters that have several tens of kV allowed isolation voltage... I think you can't.
Mates
Mon Jan 28 2008, 10:09AM
jmartis wrote ...
I think you do not understand the point. Running the whole stuff from a battery should avoid the attraction of the very HV of the upper secondaries to the primaries, because the primaries are not grounded. There should be no need for super-isolated inverter (and BTW: why four, one is enough to make AC from 24VDC and followed by transformer can easily drive the whole circuit).
Mon Jan 28 2008, 10:45AM
The only way round it is to run each stage from its own battery, and switch them on by prodding with a long insulated stick wink
Mates
Mon Jan 28 2008, 11:37AM
Steve Conner wrote ...
Ok, finally I see the problem... Thanks guys...
