  • Guests: 43
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
A question on something I should know already >,<
Spedy
Sun Jan 27 2008, 04:02AM Print
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
Ok, I honestly feel ridiculous asking this question. On Steve's MicroSSTC schematic, which side of the IRFP460 is the source/drain? I've found the pinout, just can't remember which one goes to + and which to - lol. I'm making the SSTC and I don;t want to fry a nice mosfet by putting it in backwards....
Sun Jan 27 2008, 04:07AM
source (the rightmost pin) is -, drain (middle pin) is +
Andrew H
Sun Jan 27 2008, 05:24AM
Andrew H Registered Member #1198 Joined: Sat Dec 29 2007, 05:39AM
The metal tab on the back is also connected to the drain. Make sure you use an insulating heat sink pad or your heat sinks will be electrically connected to the mains.
ShawnLG
Sun Jan 27 2008, 07:40AM
It would help when you look up the datasheet on the IRFP460. It's one of those RTFM moments.
Spedy
Sun Jan 27 2008, 05:44PM
Hmm. Ok, thanks. The pinout you gave me ... seems consistent with what I saw on another site. The datasheet I had didn;t seem to have much on pinout... Well, thanks anyway. Hopefuly I will have this project underway again :)
Now to go get some furniture epoxy for the secondary....
Edit: Another question. on the same schematic, on the part where the TC4420 connects to the mosfet, are pins 6+7 just connected together for the output, or am I missing something? is pin 3 just left unconnected? I'm a little confused....
Thanks.
Andrew H
Mon Jan 28 2008, 05:36PM
Spedy wrote ...
Yes.
Spedy wrote ...
You can use pin 3 if you wanted to use an interrupter. Using an interrupter allows you to have high peak power with lower average power (i.e. big sparks with less heating). You can also change the spark appearance using different interrupter settings. Steve Ward has a good section about this on his website.
Mon Jan 28 2008, 07:03PM
Pin 3 on the 4420 chip has no internal connection. On the TI UC37322 driver it is the enable function.
