  • Guests: 22
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
identifying flyback leads
rp181
Fri Jan 25 2008, 10:59PM Print
i recently obtained a small flyback still on the circuit board. before i unsolder it, how can i dentify the leads of the flyback? there are 10 leads, 2 of which are connected.
also, which transistor to drive it? theres one on a big heatsink, and a smaller one connected directly to one flyback lead.
any help would be appreciated.
teslacoolguy
Fri Jan 25 2008, 11:11PM
the only pin you are going to really need isthe 0v (gnd) pin and the easiest way to identify that pin is to find a circut on google or something if you are a beginner in hv i would suggest Link2 and when it is all built power it up and whatever go across the pins on the bottom with the hv output (the fat red wire) and watever pin it arcs to best that is your hv ground. i steer away from using the primary wound on the flyback transformer first because they are very thin and cannot take much input power and secondly because it is much easier smile
rp181
Fri Jan 25 2008, 11:22PM
ok, first of, its very small flyback, one from one of those portable TV's. Second, for winding my own primary, where do i winde it? there is some ferrite sticking out like in the picture on your link, but it has no wire. Do i just wind it on that and ile get some HV?
Edit: how do i figure out B C and E on the transistor.
teslacoolguy
Sat Jan 26 2008, 03:31AM
you have to wind the 2 coils directly onto the ferrite core thing and on the 2n3055 transistor you will notice if you look at it with the 2 pins facing you they will be off center. turn it so they are top of center and the left one is the base the right one is the emitter and the case is the collector
Sat Jan 26 2008, 08:21AM
Best way to find the GND pin is to connect 3 9V batteries in series, connect the negative to your HV output, connect a voltmeter to the positive and prod around the bottom pins of the flyback. Whichever gives you the most voltage (a few Volts) is your GND pin.
